j-d
Oct 17, 2014Explorer II
The check I suggested is to see if the compressor is being powered up but cannot start. Your system is what I'd call "complex" being Heat Pump and Wall Thermostat, but let's see what you find out.
It should have a Freeze Sensor which stops the Compressor if the Evaporator Coil ices up. I tinker with the simple systems, so I don't know what would happen if that Sensor fails or comes disconnected.
Do you have the Model Number for this Penguin? Maybe we can look up a wiring diagram.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
