cdl2's avatar
cdl2
Duo Therm roof A/C
Both my roof AC unit quit working.
I have line voltage to the AC units.
I have a Duo Therm digital Thermostat, but it looks like its not getting power(no info on the stat).
I replaced the stat , but nothing happened.
Checked the fuse in the unit.
Ran a new phone line type wire from the unit to the stat......nothing there either.
Any info would be great......it's hot here....LOL
  • Module board & compatable T Stat are gonna cost $238.
  • I found a trouble shooting guide on line.
    It looks like its the module board that's bad.
    Called the dealer for parts
  • That looks kinda like mine.
    I have 12 volt at the fuse, & the red wire.
    There is a circuit board in the box.
    Looks like one of the "phone" plugs it not looking too good.
  • Remove the inside trim and you should have access to the control box.
    Wires include, 120vac, black pair to freeze sensor, bundle from thermostat, blue/white to control furnace, and some black/white paired wires that carry 12vdc.
    The 12v wires should be attached with a crimp connector to the harness. Get your voltmeter on those wires to check voltage.
    Paired white/black are 12v supply.
    Blue/white is control connection to furnace.
    Yellow is 120v power bundle.
    Black to the left is the freeze sensor.
    Brown is the bundle from the thermostat.
    Or maybe your Dometic is completely different.
  • It's getting power at the AC unit.
    I don't know about 12 volt power.........Don't know where to check that???
  • Circuit Breaker ?
    There may be 3 of them.
    At the pedestal/power receptacle,
    on your RV power panel
    and on your converter/inverter.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
