pianotuna's avatar
pianotuna
Nomad III
Aug 06, 2022
duty cycle on roof air conditioner
Hi all,
I'm visiting a friend and wanted to see what the duty cycle was on their roof air conditioner. Each cycle was allowed to run twice. For each pair, the second number is the run time. Location is Longwood Florida.
The unit is a 5th wheel with one slide. 30 amp a fifth wheel cougar 33 feet from 2008. One roof air equipped with a device that starts the fans, then cuts in the compressor about 12 seconds later. The opposite happens when the roof air shuts down, i.e. compressor shuts down and then the fan.
I just discovered that the "dump" valve on the air conditioner was open. It is about 5 feet from the thermostat. For the next series of measurements I'll have it closed.
So far:
Ambient temperature 83 f (28.3 c)
Rv temperature 69 f (20.6 c)
duty cycle 5 minutes off and 9 minutes on
raised interior temperature to 70 f (21.1 c)
time to next cycle 8 minutes
duty cycle 5 and 8 (no change--odd)
raised interior temperature to 71 f (21.6 c)
time to next cycle 5 minutes
duty cycle 3 minutes and 5 (???) 2nd cycle was 5 and 3 3rd cycle is 4 and 7
At end ambient temperature was 87 f (30.5 c)
more data to be added later
  • Not sure what thermostat they have, but I've got a Honeywell installed in my RV now and one of the advanced parameters I setup was 5 cycles per hour with a 5 minute minimum guard period. This does a good job of balancing dehumidification, temperature swings, noise, and wear on the compressor.
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Dec 02, 2025
