diazr2
Mar 22, 2015Explorer
E-Z Flex ?
I am thinking about installing these on my fifth wheel does anyone out there have these in use, and if so what do you think of them.
myredracer wrote:
I seem to recall a couple of people posting in the past year something about filing a groove on the bolt so the grease can get evenly distributed.
Charlie D. wrote:
The wet bolt kit comes with bronze bushings to replace the plastic ones that wear through in a year or so. IMO, the bronze bushings and bolts will last a lifetime on most rigs with a once or twice shot of grease each year. The shackles are twice as thick and heavy as the OEM.
joebedford wrote:diazr2 wrote:Interesting. They didn't change the clearance on my rig at all.
I think I am going to pass on these because of the clearance issues.
BFL13 wrote:
I was going to get a wet kit but the RV shop guy pointed out that is only for the one bolt and the other two still wear through like before. So I lost interest in that. I don't have the E-Z Flex to compare with the basic set on mine.
joshuajim wrote:
I installed them on my Wildwood, and the ride quality has improved considerably. The only issue that I have had is that the stock clearance between the tire and wheel well has been reduced by about an inch and now on heavy bumps, the tire hits the top of the well. Not enough to do any damage, but still hits.
