JiminDenver's avatar
JiminDenver
Explorer II
May 11, 2015
Eco worthy 20a MPPT vs TS-MPPT-60 and series test
So I was able to run quick test comparing the Eco-w vs the MS today. I spent quite a bit of time trying to get the netbook and MSView to see the TS-MPPT-60, it did connect but didn't display more than the controller info, no voltages or anything yet. Luckily the Eco-w has it's display and I bought the remote display for the MS.
Both controllers went above 18a once I drew the bank down near 12v. That wasn't hard since the 8-D is on its last legs. I did notice that the eco-w was only showing 210w while the MS was showing 220w but the amps stayed the same. Even when there was two Eco-ws they swapped high and low controller on the same bank under load. I'll rerun the test to get any numbers needed.
It was a quick test and I didn't get a lot of measurements because I also wanted to run a series test with all three panels on the MS. All I can say is WOW. I used the 5000 BTU air conditioner as a load again and the biggest issue I had was keeping the controller in MPPT mode. It takes 3 minutes before the compressor will start and by the time it did the controller was in absorb. I had to turn on a heater to get back into the MPPT just to see max amps.
The three panels were pointed well but not pitched back far enough to be really lined up with the mid day sun. Even so I saw 48 amps in MPPT and 45a in absorb. 660 watts was the highest I saw out of the three 250w panels and may have seen more had the panels been leaned back farther. Once I turned off the heater the voltage of the battery started coming back up and the controller switched back in to absorb. While the AC ran there was a panels worth of power going to the bank, raising the voltage. the voltage climbed even faster when the compressor shut down. The voltage was up into the 14's when the compressor turned back on and it did so easy that I had to check the kill a watt to make sure it was on.
Being able to run the air conditioner and charge the battery at the same time was what I was hoping for. Right now I am running a equalization on the 8-D not that I expect much. Now to figure out the MSView.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
