NRALIFR
Jan 24, 2014Explorer
wa8yxm wrote:
.........Instead buy your blankets at a truck stop that sells 12 volt blankets, Put in heavy wire (At least 10 ga) to heavy duty (20 amp) socket(s) near the bed and add at least one more battery, In fact Id go with either a pair of GC-2 in series (Six volt golf cart batteries, best Bang for your buck) or a pair of 29's or 31s. For the added capacity. one 27 ain't going to cut it.
That's almost verbatim what I've done in my TC, except for the batteries. I only have room for one group 31 battery in my camper, so I've got a Trojan SCS225.
Electrowarmth used to make 12 volt, Queen-sized mattress pads with analog controls. Very good product, and that's what I have. When we travel in the winter, I run it on a low setting while we drive to keep the mattress over the cab from turning into a block of ice. I've got 6 gauge charging wires running from the truck alternator, so it's able to keep up with the draw from the mattress heater. I also replaced the Elecrrowarmth 12v plug with a Marinco plug and receptacle on a dedicated circuit, because I noticed the standard plug was getting hot.
Electrowarmth only makes a twin-sized (36"x60") mattress pad today. From the picture, it appears to still have the analog control. If mine ever needs replacement, I intend to buy two and sew them together to make one pad of 60"x72", which is perfect for a queen mattress. The two twin pads would be running across the width of the mattress, but that's OK. You typically want the leg/feet area to be warmer than the chest area anyway, and the head area to not be heated at all. I'll have to add another receptacle since there would be two controls.
MEXICOWANDERER wrote:
.............Does anyone make a 12 volt king size electric blanket with twin controls and 10 power settings? Oh, I forgot. And 180 watts of afterburner to get a bed toasty pre-warmed on a chilly night?
I don't think so. I suspect a 12v blanket that size would exceed the capacity of the standard 12v plugs and sockets. I don't know this for a fact, but I also suspect that's why Electrowarmth quit making their Queen sized mattress pad. Like I mentioned, I noticed mine was getting hot. It never melted down, but I upgraded the connectors soon afterwards. Perhaps they felt the liability risk was too great.
.......What you use ATOP the blanket makes all the difference in the world as to kWh usage.
You are so right about that. If you don't put something on top of the heated blanket or mattress pad, you will loose a lot of heat and use more power. Found that out by trial and error myself.
