Naio
Nov 17, 2015Explorer II
GordonThree wrote:
Thanks for the feedback everyone!
I picked up a Sunbeam "LoftTec" ultra-plush from the Sunbeam website, $15 off coupon so it was under $70 bucks at checkout.
I'll try it as a blanket first, and then under the fitted sheet next, see which way works better.
Putting the blanket under you works, but it's not as good as a heated mattress pad that is made for the purpose.
The blanket is thinner, so it gets bunched up under you, and it has lumps -- some sort of junctions or temp sensors or something -- that you have to position your body around.
It would be ok for testing out the concept, but if you find you prefer underneath heat you'll be spending another $50 for a heated mattress pad. They last forever, though. I've had mine 15 years at least.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
