GordonThree's avatar
GordonThree
electric blankets, $50, $150, $250, $$$$??
I was thinking to myself it might be nice to purchase an electric blanket to use while winter camping, so I can run the noisy furnace less, and keep the cabin cooler for my dog. (dog thinks anything over 30F is too darn hot)
So I go check out Jeff's website and I'm amazed at the selection he carries, with prices ranging from $50 to North of $400, for what I can tell, all the same thing - a plastic blanket (nylon, rayon, faux cashmere, faux mink, etc) with heating cables in it and some sort of thermostatic control.
I remember from my childhood my mother had a heating blanket you could feel big thick heating cables inside of, and they ran at 60hz, I could hear them buzzing. I assume that was a $50 blanket, but that was 40 years ago, maybe things are better now?
As for electricity, I have 110vac available all the time from a 2800 watt PSW inverter and 800 amp-hour batter bank... so I don't need anything like a 12volt blanket.
I'm looking for feedback from folks that have used multiple blankets in that price spectrum. is the $250 blanket really five times better than the $50 blanket?
My ideal blanket would be:
1) washable
2) queen size, single zone - its just me in the bed, and a dual-zone would have an awkward area in the "middle"
3) more than just low/med/hi heat settings
  • X5 on the electric mattress pad. My recommendation is to use a down/down alternative blanket for most. That will hold more heat inside with your body while you sleep. Then use the electric mattress pad when the blanket isn't enough. The heat from the mattress pad will rise and fill in the pocket between the pad and the blanket - the exact pocket where you're body is located.
    With an electric blanket, the majority of heat rises above the blanket. Wasted energy. And you have to set the blanket higher than the mattress pad for the same heat benefit.
  • At the cabin we had, we kept it at 40 deg during the winter. A heating pad under us worked a lot better than the heating blanket over us that we used to use. Seems that we paid about $35 for it.
    Bill
  • I would only caution the fire safety of electric blankets, we lost a bedroom to fire due to an electric blanket years ago. I won't use one!
  • smkettner wrote:
    I recommend a low voltage mattress pad over a blanket.
    x2
  • Biddeford is the only blanket maker we will use. They will replace the controllers as needed.
  • Since you have a PSW inverter any blanket will do just fine. They self destruct with a MSW inverter. I have used a cheapie for years and really don't think there is much difference between the cheap and expensive except the fabrics and stitching.
    Amazon
    X2 - safer and more effective since the heat comes up from underneath you.
  • Sorry, can't help you with manufacturer or cost but....
    We use to go the electric blanket route.
    Cons: cords to deal with and plug in. Worthless without elect. hook-ups.
    We moved to a quality down blanket.
    Pros: nice and warm, light weight, nothing to "plug in," nothing to adjust.
    Just a thought.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
