tsherv's avatar
tsherv
Electric Brake Issues - Weak Brakes
Hi,
I have a 2017 R-Pod 180. Recently I repacked my wheel bearings and inspected my brakes. I noticed that the 1 shoe on the drivers side was really worn. I decided to replace the whole break assembly and hub. Very easy replacement.
After I got everything back together, I adjusted my brakes on both sides. I adjusted them according to every youtube video I could watch. I can spin the wheel on both sides, but hear a slight drag of the brakes.
When I road tested it, I decided to set my brake controller (Prodigy IQ). I quickly realized that my brakes were not doing much of anything. I readjusted my brake controller. I ended up cranking it all the way up. As a result, I can feel the brakes working. If I'm coasting at 20 MPH and hold my manual override button on the controller, I can just about make the truck and trailer stop. I feel like they should be more powerful though. If I crank up my brake controller, shouldn't I be able to just about lock up my trailer tires?
We are leaving in 12 days for a 4,000 mile mountain vacation. I really need to get this figured out!
I've tried different combinations of brake adjustments and controller adjustments and seem to get the same results.
Any advice?
  • tsherv wrote:
    I was told that when I installed the new brake assembly, that there isn't a positive and negative wire. The dealer told me that it doesn't matter which wire you connect. Just so both wires are hooked up. Does that make sense?
    This is correct. I agree with the above poster that they need to be burnished.
  • I only put new shoes on one side. The other side had very little wear.
    As far as the connections go: I use heat shrink "butt connectors". As far as I know I have a good connection?
  • Are you sure you have good tight connections for the positive and Neg. wires.
  • I don't know how many shoes you replaced, but new brakes take some time to burnish and work correctly.
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: Oct 05, 2025
