Almot
Apr 22, 2018Explorer III
Don Piano, semi-permanent rigs don't travel to refill on propane. They run on 70-100 lbs upright propane cylinders, refilling those isn't a problem, there are either local outfits or a traveling propane truck. People keep 3 of them if they need 2 per month, one goes empty - refill it. Many local homes and businesses rely on these "cilindros", this is not just for RVs.
To refill a 1 lb propane tank, you need to keep one of those white 20-30 lbs RV tanks - those are refilled at the same outfit as upright cylinders. You don't have to refill 20 lbs tank often for this, as 1 lb tank is only for emergency-like situations. With 7 people 1 lb won't last long, though.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
