ronniedean1234
Mar 20, 2014Explorer
dougrainer wrote:
Check to see if the battery feed power is on a 12 volt Auto reset Circuit Breaker. The breaker may be weak or the pump is pulling excess amps and that is the reason for the Start and Stop. Doug
Also with cold weather operation the Hydraulic fluid is much thicker therefore requiring the pump to work harder pulling more amps possible tripping out the Circuit Breaker...
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
