I am having a problem with the electric pump shutting off during operation of the slide. When i push the switch the pump starts and everything works; then shuts off during the slide out motion. Then i...
As mentioned above it may be a self resetting breaker. Here is a link to what they look like. I would guess it is most likely 40 or 50 amps. Should be located near the hyd pump and battery. Good luck.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
