RJsfishin
Mar 20, 2014Explorer
I had about the same as you describe, only mine just wouldn't run at all sometimes. It was definently a bad connection somewhere.I got real tired of looking for it. Then someone here told me that my system activates the ground on the solenoid, not the hot side. So I installed a push button switch on the dash that's labeled "manual override". All it does is ground the solenoid on the pump motor. I have had to use it many times, and it has never failed to operate.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
