Golden_HVAC
Apr 19, 2015Explorer
Hi,
Born Free is built on the E-450 chassis last time that I saw one, and that is only 9/16" studs that take about 150 foot pounds of torque, not much for a modern electric battery powered impact wrench to handle, no need for anything larger!
I always use the stabilizer jacks to raise and level my RV when I needed to change a tire on the side of the interstate. I also used them when changing the brake pads and rotating the tires. Just use the jacks to do a normal 'level' and not to raise the axles. You are transferring about 2,000 pounds to each jack to make jacking up the axle easy. Then should a hydraulic line leak, or someone push the retract button, or something else go wrong, the full weight is still supported by my 4 ton bottle jack, not the leveling system.
I use a 4 ton jack because a 6 ton jack required to many strokes of the handle to lift the axle by 2". 3 ton takes to much pressure to move the handle, and is not really rated for my rear axle max weight of 6,000 pounds per side.
I still use the 18" long breaker bar, and 6" long extension required for the dual rear wheels. Make sure that you loosen the lug nuts about 1/2 turn before lifting the vehicle, or the tire might spin on you. Also my Ford has a emergency brake on the rear of the transmission, so once one rear tire is off the ground, it will no longer keep the RV still. Block the other tires! The leveling jacks will also help keep them still in my case, because mine do not fold up, like other brands to!
Good luck,
Fred.
Good luck,
Fred.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
