j-d
Apr 19, 2015Explorer II
From Harbor Fright, you can get an air-over-hydraulic jack
that will run off your tire-inflating air compressor at 110-120 PSI.
While your campground pedestal or onboard genset is supplying the compressor, it can let you also use a 120 volt impact wrench
HF doesn't sell the 7/8" deep impact socket you need for E-Series wheels. I ordered mine from Amazon.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
