j-d
Apr 19, 2015Explorer II
Wish I knew which compressors would run the jack. Looked for the air demand on the jack and all HF showed was pressure. No CFM. Looked at the 20-ton TrackRig linked and only a PSI again, no CFM...
Recently needed to do some air chisel work and tried my HF Pancake, the $59 one, and it got the job done handily. I've used a 3/8" "butterfly" impact with it and had good results, but I'm sure a 1/2" impact would fail. Also, it's only 100 PSI.
The impact I pictured is 120VAC Plug-In Electric. I have one and it works well on E450 lug nuts. Has to be used with a deep impact socket. Standard socket doesn't let the tool stay lined up with the studs because of the rear hubs. An extension dissipates some of the wrench's torque.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
