robertjhunt wrote:
First time running the generator. Only the converter smoked.didn't trip any breakers or blow any fuses.
You just joined. BAD forum conduct to not post correct answers to questions. Year/Brand model RV and Model of Genset was requested and you have not responded. Think of it this way. Would you state you have a Ford problem on your car and expect help without Year Model and specifics on the Car? Always respond with answers to requests. Gets you better and more qualified help. Also, HIGH voltage or surge will NOT cause breakers or certain fuses to trip. REVERSE polarity of the 12 volt positive and negative either at the Converter or at the Battery will "smoke" a converter when 120 is applied. Doug
