acritzer's avatar
acritzer
Explorer II
Jun 24, 2018
Electric Jack has stopped working
Anything I might be missing? The fuse is good. The light on the jack works. The camper is plugged in. It worked fine prior to winterizing and sitting through the off season. Every once in a while I'll try it and it sounds like it's trying to go...but only for a half a second?
Thanks
  • I can manually crank it just fine. It's hard to imagine that it's a grease issue.
  • When I first bought mine my Cousin told me to take it apart and grease it really good, He said his was real slow until he did that. I greased mine as he advised, I got to thinking and the other day I drill a hole, tapped it, and screwed a grease fitting into the hole now I can give it a shot of grease every once in a while without taking it apart periodically to grease it.
  • Don't know but can you crank it a few turns to loosen it up?
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
