Terryallan
Aug 21, 2018Explorer II
swimmer_spe wrote:
My electric tongue jack stopped working midway down as I was hooking it up. Fortunately, my truck's tire iron was the right size to crank the jack up for the drive home.
I get home and low and behold it works. I did notice it does wiggle a bit. So, I will try to tighten the mounting bolts. Could that have been the issue? Could it simply be that it wasn't getting a good ground?
IF it is a ultra tow. It could have gotten hot, and once it cooled down started working again. Yes mine did. Once I removed the thermal relay on the outside. It has never done it again. BTW. It is still protected by fuses.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
