jrdebono's avatar
jrdebono
Electric lid lift assembly
I have a 2002 Coleman Bayside PUP. The other day I tried to raise the roof to get some gear and the motor drive failed to move. Thought it was a battery issue and so plugged the camper into a 30amp service and still no go. So I activated the manual override switch and started hand cranking the roof lift. I got it up about a foot and then it wouldn't move. I could not lower or raise the roof. I have been searching for a replacement motor and found one from the Coleman web site at it will cost $350.00. I tried to contact my dealer and got no response.
Is there a cheaper replacement part or is there a way to "fix" it?
  • I removed the motor from the gear box and powered it up and tried to use the up/down switch and the motor did not spin. I cycled the automatic/manual switch while running the test and the motor did not rotate. I found a replacement on EBAY and may have to change the plug though.
  • I wouldn't buy a motor until I found out what was wrong with it. If you can't make it work manually then something else is wrong.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
