buylow12
Oct 09, 2015Explorer
I'm not worried about it. It's more that I'm just interested to know. If I wanted to I could run both my AC's and then crank up all three heater because it's too **** cold. However I'd prefer to do whatever is most efficient. Don't you worry about me, I'm as worry free as can be. I am living a dream after all ;)
The electric here you get 150 kwh free and then it's 0.086376/kwh. I also found out they have a propane delivery guy that comes by every Friday and charges 3.15/gal. My credit card is on file now and all I have to is call sometime before Friday and they'll fill it up whether I'm here or not. So they seem equally convenient. Even if I had to drive to fill it up there is a place not a mile up the road, it's not exactly slave labor were talking about here.
Anyways from what I know about fridges I don't see how running it on propane couldn't be more efficient. From what I've heard a two way fridge on electric takes 5x or 10x the amount of electricity vs a traditional home unit. On top of that, at least when it's hot out, it seems to do a rather poor job of keeping the freezer as cold as possible. I've noticed when it's hot out and I'm running it on electric that my ice cream tends to get soft. I don't have that problem on propane and that's enough reason alone to run it on propane.
As far as the heater I have both the built in furnace and a ventless catalytic heater. I basically never use the furnace because as said earlier it's not particularly efficient. However the catalytic heater is supposedly 99% efficient or some such. I know using them in Rv's horrifies so people but I have to say I'm not concerned in the least. However I'm thinking I'll use the electric space heater just for convenience. Plus I can place it in the bedroom and only heat that area rather than the whole place. However I'm definitely going to check out that calculator, because I'm INTERESTED not WORRIED, lol.
Lastly as far as the water heater I'll probably run that on propane too because it heats the water up both warmer and quicker than the electric. In addition I'm pretty sure it'll be more efficient. I would think I could use that calculator to find out either way for that also. I know back at my home in Jacksonville gas was always more efficient.
Both electric and gas are about the same hassle, which is to say none at all, so why not use whatever is the most efficient?
Tim Czarkowski
TotalTravelers.com
Tim Czarkowski
TotalTravelers.com
