Blacklane
Sep 18, 2023Explorer
The devices that have the wire wrap around a screw are not appropriate for the vibration environment in an RV. You need to choose ones with screw clamps, often labeled as "commercial". Even back-stab connections are more reliable than wrapped screws in an RV.
People often say that RV self-contained devices are junk, but the ones by the major suppliers are approved by UL and CSA and are perfectly safe. They are specified in the National Electric Code (NEC). They do have to be installed correctly using a special tool.
People used to say that crimp connections were junk, however that is the only kind of connection you will find in a modern automobile because they are the most reliable.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
