RLS7201
Sep 19, 2023Explorer II
Blacklane wrote:
The devices that have the wire wrap around a screw are not appropriate for the vibration environment in an RV. You need to choose ones with screw clamps, often labeled as "commercial". Even back-stab connections are more reliable than wrapped screws in an RV.
People often say that RV self-contained devices are junk, but the ones by the major suppliers are approved by UL and CL and are perfectly safe. They are specified in the National Electric Code (NEC). They do have to be installed correctly using a special tool.
People used to say that crimp connections were junk, however that is the only kind of connection you will find in a modern automobile because they are the most reliable.
Exactly!
The RV receptacles are good if installed correctly.
Screw downs get loose shaking down the road.
Look at how many problems have ben posted about circuit breaker panels.
The OEM receptacles in my 95 Bounder are still good.
They get used for 1500 watt heaters with no problem.
Richard
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
