HiTech
May 02, 2013Explorer
I was thinking low voltage to motor too. What is battery voltage before using slide, while using slide, after using slide? What is voltage at motor contacts in the same situations?
My TT had the same issue and it ended up being a pinched wiring harness to the motor fixed under warranty. But I would look first at the seemingly full battery. My TT battery will indicate full on the built in panel but be low and run the slide motor slowly. It will indicate the same when well charged and run the slide motor much faster.
Jim
Jim
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
