Artum_Snowbird
May 02, 2013Explorer
One thing to check is the actual running voltage. Take the leads right off the motor and see what it is. Then take a good set of jumper tables and bring them to the motor and check what the running voltage is then. If you have a bad connection from the power source to the motor, you will really see a difference.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
