hogbob's avatar
hogbob
Electric step
Hello,
My electric step will not stay out in the "off" position. It goes in and out as the door opens and closes. But the step only stays in instead of out when the switch is off
Thank you for any help.
Kenny
  • wa8yxm wrote:
    Kwikee makes two controllers.. one extends teh switch when the door switch is open (I think this is the new style) and the other when the door switch is closed (I think this is the old style)
    If you are replacing the step controller (Old with a new style) one way to get the steps to follow the door is to reverse the motor leads. So Out is in and in is out.
    Not the best idea because the ignition override would then EXTEND the steps but you can disable that.
    I can see a short cutter doing it that way.
    This is about the only thing I can think of.
    I don't really know what you said and I have very high regard for your knowledge but what are you suggesting? I don't think he should change anything. He should follow the step by step trouble shooting instruction in Kwikee manual 888. That is if his steps are Kwikee steps.
    The Kwikee steps are so simple mechanically and electronically, oh my goodness why try anything else. If they don't work as they should repair them don't jury rig them except to get to a location to get them fixed and even then jury rigging is questionable.
    Once again I respect your knowledge very much and you seem to have a great background in electronics, but, I don't agree. If they aren't working repair them and don't use them until you do.
    There is also the fact you said "OFF"
    There are two swich functions for the Kwikee steps
    Old style it was clled POWER and OFF meant.. Well.. OFF
    new style it is called OVERRIDE and OFF, means steps follow door
    ON means it stays out (or in your case in)
    Strongly suggests an old controller replaced with a new one, but still using the old door switch.
  • You replaced the controller with the wrong controller. Get the right controller and replace the wrong controller.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
