Snowman9000's avatar
Snowman9000
Electric toaster <600 watts
A toaster of less than 600 watts would be useful to me for my particular inverter. Anyone know of one?
Our cheapie 2 slicer uses 740W, just too high. I looked at trying to cut or switch off one side. Unfortunately it's not a simple as that. The center run of heating wire is common to both sides, wrapped around a divider. Shutting off the remaining one half of one side might get under 600W, but it would be close. I searched for a one slice toaster, and they existed 50-60 years ago, but not now.
Please, first person to say they use the stove, grill, toasting gadget for same, etc., gets it! :)
I'm well aware of those options.
  • Will a toaster of less watts work very well?
    I know what you mean. Try asking about coffee!!
  • reason for the low wattage ?
    overloaded circuit OR want to use existing inverter
    the first is easy turn something off for a few minutes
    the second.. maybe use a buck transformer between the toaster and the inverter supplied outlet..knock down the voltage 10~20% knock down the wattage, toasters are resistive heat..reduce the voltage and the power load goes down
    that or a bigger inverter
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 16, 2025
