Freelander
May 01, 2013Explorer II
As other posters have indicated, extra capacity is not a bad thing. I caution that you should measure the diameter of the existing unit to make certain that whatever unit you purchase will properly fit the opening in the trailer frame. If I remember correctly, the larger capacity jack is larger in diameter and may not fit the current opening in the trailer frame.
Best of luck.
DKS
Best of luck.
DKS
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
