NJ6PACK
Apr 29, 2013Explorer
Electric Water Heater went up in smoke
On my last trip of 2012 the water heater had a problem.
When it was on electric I could smell something burning and I heard an arching sound in the area of the water heater so I removed the dinette seat and found the wires on the relay melted (110vac wire) so I switched to propane and everything was fine. The water heater works fine on propane
I am assuming the relay is toast so I Googled the part # on the relay and I can get it for under $5.00, My concern is what would cause this to happen, A voltage spike?. Looking at the manual I don't see anything else like a circuit board...Did I miss something?
Is there anything else I should check?
The water heater is a Atwood 10gal DSI water heater
Relay is a ZETTLER part # AZ2280-1A-12D
Here are some Pictures
