BigWapiti's avatar
BigWapiti
Electrical - smoked up the cabin
I need a starting point. A couple weeks ago we were camping - battery went low so hooked up the generator. Ran for some time then I got a wife of hot wires. Turned off the generator - finished our day out and went home. Plugged the camper into the 110 outlet to finish charging the battery. Sat on there for several days (no problems). Battery didn't charge - assuming the battery went bad (it's only a year). Put it on the charger and the charger read error. I put in a new battery and a spark when connecting the ground. I was stupid and put it on anyway - smoke began pouring out from under the sink area.
I have solar - but don't think that's the problem. With the smoke cleared, I don't see anything that looks burned (under the sink anyway). I'm going to pull the step up to the bed off and check the controller in there. That's probably it.
Can someone let me know what that's called? I can't seem to find a parts list if it needs replaced. I'm also going to search for shorts - its' the same smell I smelled when we were camping. That was a lot of smoke
Crud. Electronics is not my thing - but I'm not working a lot now either so it's going to be up to me. Any help would be appreciated.
Having RV issues? Connect with others who have been in your shoes.24,329 PostsLatest Activity: Oct 28, 2025
