frankraney's avatar
frankraney
electrical adaptor
Am looking for a 50 amp to 15 amp adapter. Specifically the 50 amp end that connects to trailer - to a 15 amp. I can not find one. What is the plug model number that goes to the trailer (not the pedestal). If I knew that I would make my own.
  • Get a 50 to 30 and a 30 to 15/20
    There will be times you need a 50 to 30
  • Only use those 50 to 15 adapters to keep the batteries charged. Most anything else on a modern RV will draw too much current for a 15 amp service.
  • 2oldman wrote:
    Something like this?
    Amazon has all kinds of stuff.. but I'm confused on exactly what you mean.
    I've used this adapter for several years now at the S&B and it does a good job.
    Do you have a 50a twistlock connector on the trailer or just a 50a cord?
    Twistlock see above. Otherwise you have a NEMA 14-50 plug on your cord. PPL has this:
    http://www.pplmotorhomes.com/parts/rv-power-cords/110-volt-electrical-adapter.htm
  • Not sure which plug, but the twist lock is NEMA L14-50 , straight blade is just 14-50.
  • I bought a heavy duty extension cord and a 50A female end. And made my own. Have used it for years with great results at home.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
