Earl_E
Jun 23, 2018Explorer
wa8yxm wrote:. I'll check for gunk because the bump doesn't line up the hump!
4 6 or 7 pin round or flat.
Round connectors have a bit of a "bump" on them that a notch on the dust cover locks down on. If the dust cover spring is not springy enough it wont' lock (or if you do not push it far enough on) a rubber band over the cover and plug body may help till you can make other fixes.
