vermilye
Sep 12, 2017Explorer II
What you are leaving out is that when you use an inverter to run the refrigerator on 120V, the power is still coming from the battery. The input to the inverter will be around 10X the current coming out of the inverter (wattage is the same, so one tenth the voltage will have to push ten times the current).
With the losses produced in the inverter, I suspect you will be better off running directly from the battery.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
