MrWizard
Sep 14, 2017Moderator
a honda inverter generator, running in Econ mode will use what ever throttle, little or high to match the load
it will do the same thing with out Econ mode
the difference, is that in econ it idles lower and runs at the bare minimum needed to maintain voltage at the load amps/watts being used
with econ OFF it idles faster and the applied run power is slightly higher than the minimum needed, it will ramp up faster when more load is applied, than when in econ mode AKA response time to load increase is faster with econ OFF
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
