2chiefsRus
Dec 26, 2013Explorer
You said you got the lights and heat back on - more information on what you did to make that happen would likely be helpful. Do you have anything working that is plugged into an outlet? Sounds like you only have 12 volt items running now? Do you have an inverter in your RV? Do you have a generator? If you do, do you get better results if you run the generator?
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
