RoyB
Dec 26, 2013Explorer II
When you get your multimeter this shows what you should read on the shore power side of your 50 AMP service...
Please use caution with you multimeter probes as you will read 240VAC between the two HOT connections.
I have one of these RV 120VAC Voltmeters plugged into a 120VAC receptacle in my trailer at a good spot so I can give it a quick glance and see that 120VAC is in the "GREEN" safe zone...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
