exp2ex
Jun 30, 2016Explorer
UPDATE !
So looks like my new battery is completely destroyed. I removed in from the rv and put on a smart trickle charger overnight and can't get it over 7 volts. My old battery would at least hold 8.5v.
I put the old battery in to see if the interior lights would at least work. I pulled out the breakers to check for corrosion, there is none. I put them back in and the fan & AC would turn on. Then I turned the lights on and they were very dim and the ac/fan stopped.
All the 12v fuses have good continuity and all the C/Hammer breakers seem to be working fine.
Got me a volt meter from harbor freight. It is defective. One wire has no continuity. YEA !
So for a break down. I need a trouble shooting guide for the converter.
Step by step instructions to run through before I buy a new inverter.
The one I have now is a : WFO WF-8955AN
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
