wa8yxm
May 24, 2021Explorer III
Possible problems
Blown fuse
Burn Out Bulb
Secondary Switch turned off
Broken wire
Broken connection.
NOTE this last includes a failure ground side on the lamp
Oh and if you are still using incandescent lamps broken socket insert (Bayonet type lamps like the 1141) if that's the problem I can send you a repair kit I no longer need... If I can find it. NOTE the kits I have are NOT for sale.
Blown fuse
Burn Out Bulb
Broken wire
Broken connection.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
