Sandberm's avatar
Sandberm
Electrical outlet wont work
I have a 1995 Nash 20n and me and the wife love it but the electrical outlet by the kitchen sink does not work. All the the other outlets in the tt work but that one.
When measuring voltage with my multi-meter i get 119v on all the outlets that do work and 89 across the one that does not work.
I put a new outlet in and that did not work. Any ideas? We've done our best not to let this older tt go downhill and have tried to keep everything working but this one has me stumped.
  • First suspect is a GFI but that would usually be a second outlet not working.
    Probably need to inspect the string back to the breaker. Most probable IMO is the exterior outlet could have a corroded connection.
  • you have a voltage drop on that one so you prob have some burnt/melted wiring inside the wall somewhere, you'll have to trace it down and clip it out of there and install some new wiring. Look for chewed wire from rodents too
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
