mrgreetis
May 25, 2015Explorer
Another possibility - Did you switch off the 120 volt shore power without disconnecting the battery? With the 120 shut off, the power converter would not keep the battery charged and you may have run down the battery to essentially 0 volts. No battery means no 12 volt power, no lights, no slides, no fridge or anything else with a control board. Unless the battery gets charged up (probably too late for that with your current battery) or your converter supplies your 12 v, you may be out of luck. Hope you can get it to work.
Mike
Mike
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
