BFL13
May 26, 2015Explorer II
petegent8 wrote:
Thank you to all that assisted with your suggestions. Great time and money saver! The battery was the culprit. New battery and the season is officially underway. Much appreciated.
Peter
Wrong. Even with a dead battery, your converter powered by the 120v should have supplied the 12v.
All you did was put in a new battery, (which was needed most likely), but with no converter working that battery will also soon die.
With 120v on, measure the voltage at the battery posts. It should be at least 13.6v if the converter is working and the "12v" juice is getting as far as the battery.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
