BFL13
May 31, 2015Explorer II
petegent8 wrote:
OK BFL13 I`ll look forward to that link.
It was on the Parallax site but it is gone!
anyway it is simple, confirm 13.6ish volts at the converter output, reverse polarity fuses not blown, fix battery wires if they are blown and replace fuses.
If that wasn't it, confirm 120v coming in (120v circuit breaker, 120v at receptacle converter is plugged into--might be GFCI and tripped)
You are getting battery 12v to fuse panel so your battery fuse and battery disconnect switch are ok and will not prevent converter 13.6v going the other way once you do have 13.6 at the fuse panel.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
