petegent8
May 31, 2015Explorer
Results of multimeter tests today: 98 Jayco Eagle 312fks,Todd PC45b converter(see several negative forum comments regarding this model converter).
125 at campground power pole.
125 at camper outlets.
11.9 at battery.
123 going into converter, green light on converter.
nothing at converter back w/battery disconnected.
11.9 at back of converter with battery connected.
11.9 going into fuse panel w/battery connected, nothing coming out.
nothing going into fuse panel w/ battery disconnected.
Everything working when battery is connected as stated in earlier post.
I had shore power off for a few days after suggestion above to not let battery run down. I am thinking converter is not working, no fan when converter is plugged in. Should I fire it all up as is for a few days to see if it raises battery charge? I am not that skilled with electrical so appreciate any suggestions. Thanks
11.9 at battery.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
