grullman's avatar
grullman
Electrical problem
Approx. a couple hours after connecting to the 50a shore power I experienced electrical problems. The air conditioners were laboring to run. I shut off the air conditioners then noticed that the GFI outlets and the microwave were not on. (I should explain that when I set up the first thing I do is check to see if I have power. I do this by looking at the microwave clock.) I unplugged from shore power contacted the camp office and they sent there repair man. He checked the shore plug and found the neutral connection was loose or broken and connected me to the adjacent site shore power. I continued to have electrical problems. My question is would the broken or loose neutral cause my electrical problems. The site repair man said the problem is in my motorhome. I feel the problem was caused by the camp ground shore power. Prior to leaving home I exercised the generator for one hour while I was packing up the motorhome and the unit is plugged into my home power continuously without any problems.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
