gooden91's avatar
gooden91
Electrical problem
2021 grand design reflection rv electrical problem-bedroom/bathroom fuse keeps blowing when I sit on the bed.
  • It's also helpful if you return to the forum to read responses to your question.
  • Is the pass-through under the bed? Look in there for a bad wire/wiring as described by way2roll.
  • Sounds like a damaged or loose wire under the bed. Look for a wire somewhere under the board under the mattress, under the frame, in a hinge, in an outlet etc, that is loose or has rubbed and exposed the wire. If it's shorting other things in the circuit, it's probably an outlet.  Likely when you sit on the bed, the wire is moving and arcing or getting pinched or touching metal and causing a short.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 02, 2026
