Dutch_12078
May 22, 2016Explorer III
Hmmm, something's not making sense. A converter only outputs 12 volts from a 120-volt input, and the A/C's also run on 120 volts. Normally, there are no 240 volt appliances in most RV's. Could you mean an "inverter" instead that outputs 120 volts from a 12-volt input? Although the A/C's would not be connected to that, due to the high current draw. Do you have a single thermostat with a multi-zone temperature setup?
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
