scout3351's avatar
scout3351
electrical problems
Having electrical issues after loaning out trailer for a week. AC doesn't work, refridgerater works only on gas, sparks blowing out of converter. Opened converter because I could see debris behind the fan. Both capaciters were split open with the contents laying all over. While checking things out I got a scare when I was checking the neutral bar. I'm no electrician but I don't believe the white wire going to the neutral bar should read 120v. Red wire going to breaker is 120v. Black wire going to next breaker is 120v. Ground wire to grounding bar is fine. If I just plug in with 120v cable its fine. It's when I plug in with the 220v 30 amp cable that things get ugly. How can the neutral wire get hot when plugged in with 220v?
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
