CA_Traveler
Aug 14, 2019Explorer III
cougar28 wrote:Yes the neutral carries the difference of the 2 loads for a 50A RV pedestal plug. I took the post to mean both hots are connected to L1 or L2 like the cheater cord allows.RLS7201 wrote:philh wrote:
Two questions,
1. I've heard of some wiring the same 120V phase to both sides. Wouldn't this drive twice as much current through neutral line?
2. Other than the problem of hooking to a single phase circuit, why wouldn't the AC units be 2 phase? Wouldn't that be much more energy efficient?
What is being discussed(?) here is called split phase. The return path on the neutral line carries an inverted sine wave from L1 & L2. When L1 & L2 carry a balanced load, there is no current flow on the neutral path.
Maybe you can follow this.
Richard
RLS7201 is 100% correct. The neutral only carries the unbalanced load between the two line.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
