RLS7201
Aug 18, 2019Explorer II
myredracer wrote:road-runner wrote:I spent a career as an EE in the construction biz and can tell you it's always been line 1 & line 2. Go look at a 120/240 volt panel, meter base or fused disconnect switch somewhere and see what the labeling says on it. A 120/240 volt circuit/service is commonly called "single phase" but each hot leg is never referred to as a phase.OMG... I wish people would stop referring to "phases" in reference to 120/240 volt circuits and services.You might have a tough time with this. For examples, I used google to search for "120/240 volt circuits and services", and 4 of the first 5 hits talked about phase. My similar thing is that I wish people would stop bringing up calories when I go for the cookies or chips.
Go by what internet "pros" say if you want tho...
As an EE you should know better. The true definition of 120/240 service is indeed "SPLIT PHASE". There is no other way to define it. If not for the split phase definition, there is no way to explain why the neutral lead can be the same size wire as L1 & L2 wires. Single phase is for rookies & EE that don't truly understand the mechanics of split phase.
Richard
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
