JeepCollector91
Nov 21, 2015Explorer
I just reweighed the 1998 Ford E-Super Duty chassis now that the entire motorhome structure and rear frame extensions have been removed. It is now as close as I could get it to the way it left the Ford plant as a cutaway cab/chassis. Only the roughly 48" mid-section frame stretch remains.
I fueled up to the same half tank fuel level as the first weigh and again it was only me onboard.
Steer Axle: 3460-Lb
Drive Axle: 2420-Lb
Gross weight was 5,880-Lbs
That is a huge weight loss down from 12,520-Lbs.
Now it is time for the rebuild...
Steer Axle: 3460-Lb
Drive Axle: 2420-Lb
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
